Up Topic Welding Industry / Technical Discussions / P-number and F-number
- - By mstech3 Date 11-21-2005 06:51
Dear All,
pls update me about P-number and F-number.
Also update me about the basis on which these numbers were given.
thanks & regards,
mstech3
Parent - - By jon20013 (*****) Date 11-21-2005 12:45
P-Numbers apply for base materials, F-Numbers apply for filler metals. Each is "grouped" into alloy "families" as indicated in ASME Section IX.
Parent - - By cas (*) Date 11-22-2005 02:31
P#= Parent mat'l
F#=Filler mat'l
please correct me,if i'm wrong.:)
I'm learning too.
Parent - By 56780 (*) Date 11-22-2005 22:58
cas,
Your are correct.
Parent - - By 803056 (*****) Date 12-02-2005 20:05
As long as you are talking about F numbers and P numbers, don't overlook the A number when working with either ASME or AWS D2.1. The A number is the chemical analysis of the weld deposit. The A numbers apply to ferrous metals and are grouped based on chemistry of the diluted weld deposit.
Good luck - Al
Parent - By jon20013 (*****) Date 12-02-2005 20:11
or the "M" numbers in AWS terminology! lol!
