I couldn't find anywhere if one joint type change to other joint type for instance change of butt joint to a t-joint without changing of joint dimension we must reissue a new WPS or not?
Depends on which code your working with. For D1.1, in general terms, yes, a new WPS would have to be issued. For ASME, no, joint design is a non-essential variable.
