I would add, make sure your amperage is high enough ( your wire speed) and keep a very consistent wire stickout and pulling a longer arc will immediately reduce your depth of penetration.
Also, us a " head on " or a slight drag angle to maintain a keyhole effect in the joint. A push angle will push weld metal in front of your arc and close it off from penetrating through consistently.
