Up Topic Welding Industry / Welding Fundamentals / Where's the torch striker?
- - By supermechanic (**) Date 06-10-2006 23:04
Spend too much time looking for the lighter when you "just set it down, it has to be here someplace"?
Get a double ended dog chain clip, the spring loaded type.
Attach one end to the loop at the back of the striker, the other end stays clipped to a belt loop on your trousers on the side of your dominant hand.
You will never need to search for it again.
Parent - - By devo (***) Date 01-08-2007 19:36
The retractable clips sold for ski passes work equally well also.
Parent - By Sourdough (****) Date 01-09-2007 05:29
Can't stand things hanging from my belt when I'm traversing in tight spots. I usually clamp my special vice grips to the material I'm working on and strike an arc to start my torch. No striker needed.
Parent - By makeithot (***) Date 01-17-2007 16:19
If you wear carharts. like most welders it turns out that there is a pocket just made for that tool.
Parent - - By shadowelds (*) Date 06-27-2007 02:23
bend a rod hook one end in pocket bend the other end slip striker on that end, basically two opposing Js one J  in pocket other J  holds striker
Parent - - By ssbn727 (*****) Date 06-27-2007 03:17
I usually use my eyes and my hands ;) although I've been known to use a mirror or two & some wire after I accidently dropped it ;(
Parent - - By swnorris (****) Date 06-27-2007 11:05
I just open the striker end, run it through a belt loop on my jeans, and close it back.
Parent - By jwright650 (*****) Date 06-27-2007 11:18
Same here.
Parent - - By bozaktwo1 (***) Date 06-27-2007 17:01
Striker?  Oh, you mean the BIC lighter????  I tie-wrap that sucka right to the torch leads.
Parent - By billvanderhoof (****) Date 06-28-2007 00:44
If I'm on the ladder it's on the floor, if I'm on the floor it's on the ladder, after I look in both places I usually find it in my pocket.
Bill
