Hi in our lab the technicians sometimes use a mapp air torch to silver braze/solder together small parts using 45% silver filler metal. I wanted to try a few things which couldn't be done easily with the mapp air bernzomatic torch as the long heat cycle quickly cooks the flux. I was curious about using the welding power supply as a heat source. I have both a tig torch and a carbon arc torch which lets you touch two carbons together to strike an arc. I wanted to join a bunch of 1/8" ss rods into a 1/8" thick stainless steel plate with 1/8" holes drilled through.
Any suggestions as to how to do this job without access to an oxy acetylene torch?
TIA
