Forum AWS Website Help Search Register Login
Up Topic Welding Industry / Welding Fundamentals / Mobile Add Ons
- - By yorkiepap (***) Date 09-09-2006 14:13
This is an addendum to my previous post "Mobile Unit". The photos are methods I used to incorporate features I may need while out on a jobsite.
1st photo: Folding welding surface 32" X 16" made with 1/4" aluminum
http://i55.photobucket.com/albums/g159/yorkiepap/DSCF0211.jpg
2nd photo: Folding surface in upright position
http://i55.photobucket.com/albums/g159/yorkiepap/DSCF0212.jpg
3rd photo: 1.5" square tubing welded to trailer frame with bottom closed in and drilled for water or moisture drainage. Locking nut 5/16 X 18 welded to outside to tighten vise support.
http://i55.photobucket.com/albums/g159/yorkiepap/DSCF0213.jpg
4th photo: Vise assembly mounted and locked in place.
http://i55.photobucket.com/albums/g159/yorkiepap/DSCF0214.jpg
5th photo: This is a homemade bending jig locked into vise to bend metal up to 2" in width and 1/2" thick. I have a set of different radius inserts that can be quickly changed for different applications.
http://i55.photobucket.com/albums/g159/yorkiepap/DSCF0215.jpg
Hope these photos provide some solutions to those who may want to add versatility to their welding units...Denny
Parent - - By Bob Garner (***) Date 09-15-2006 21:33
I like that little bending jig!  Do you fold the bar stock around the radiused insert by hand or is there a rotating device that wraps it around for you?
Compliments on some creative solutions.
Bob
Parent - - By yorkiepap (***) Date 09-15-2006 23:55
Hi Bob,
Thanks for the compliment. Yes, I bend the stock manually around the radiused insert and if it is hardened metal, I will heat it red. The steel post I made threaded at the bottom so I could change them also for different radii. If I have to make a really tight radius, I just reverse the application and wrap around the rod. Works both ways. BTW...there's a 1/2" X 2"W X 4"L steel plate welded to the bottom so I can chuck it in the vise.
I'm hoping to soon finish a really inexpensive rotating welding positioner that will surprise you. Quite simple and efficient and lots of torque. :>))
Denny
Parent - - By Sourdough (****) Date 12-22-2006 04:48
Yo, Yorkie dad -
Made a bumper for my Duramax out of Cat 3406 timing chain. Will definately deflect the next deer that intends to inflict more than 3k damage to my truck. When you finally get photos you'll get a sh*t load. My promise!
Parent - - By yorkiepap (***) Date 12-22-2006 21:58
Hey SD,
Just want you know I hold a man to his promise. I want to see, and I'm sure others here also, want to see some photos!!! Ok, 'bro....have a great holiday...Denny
Parent - - By Sourdough (****) Date 12-29-2006 04:38
Hey Denny, I'm the proud Papa of a baby boy this holiday season. Wyatt Lee is 8lbs, 9oz's!!  Happy New Year!!!!
Parent - By yorkiepap (***) Date 12-30-2006 02:11
You did good SD!!!! That is a good holiday......Have a super New Year bro'.....Denny
