Up Topic Welding Industry / Technical Discussions / SS Pulsed Mig Parameters
- - By JAYDESAI (*) Date 11-13-2008 03:45
Hi all...I am trying to weld SS 304 using 98Ar-2CO2 and Fronius 2700 power source. Spool is 308. I tried a lot to set the pulse parameters, but not able to get a desired quality of weld. I searched the whole manual as well as internet to get parameters, but failed again. Can anyone suggest me the best parameters for this kind of welding in the thickness range of 1.5 mm with 1.5 mm sheet, fillet welds? Any literature to learn in depth about pulsing also would be a great help later on.
Thanks.
Parent - - By Stephan (***) Date 11-13-2008 07:29
Jaydesai,
you have PM.
Were great if you might response to it as I am sure that your issues are straightforwardly solvable.
Best regards,
Stephan
Parent - - By JAYDESAI (*) Date 11-13-2008 11:49
Hello Stephen,
See your PM too.
Parent - - By JAYDESAI (*) Date 11-15-2008 08:32
Stephan,
Have sent the details to you, pl see ur pm..coz i dont hv your mail id too.
Thanks.
Parent - - By Stephan (***) Date 11-15-2008 11:15
Jay,
I've already sent you a bunch of appropriate literature (as pdf) by using your email-address given.
Are you having a size-limit with your email-inbox?
Stephan
Parent - By JAYDESAI (*) Date 11-16-2008 07:32
Have sent you an alternate e mail in ur PM.
Parent - By Steve.E (**) Date 11-13-2008 11:44
Hi jay , I have a couple of the same machines and have found on thin material its sometimes best to turn off pulse and go to regular short arc.
    Makes for an expensive short arc welder though.  :)
Parent - By tinner20 Date 11-22-2008 20:46
get a remote box and set it to adapter pulse no parameters necessary. Set trim and go--
