call highway 60.......580 767 0768. they have em.
you can get them new from lincoln but i think they are around 200-250
dam I guess I better keep mine then if there going for that much. they seem to do a pretty good job but still sometimes smell like a little gas when I chage the oil in it
you carb is leaking fuel back into the air cleaner sounds like the float is out of adjustment mine does it too just change it about every 50 hrs and it should be ok i do it when i remember lol
is it hard to change the float? I usually run the gass outta the motor when I am done useing it because sometimes it will sit a couple of weeks before iuse it again
dont change it adjust it did you put a gasket between the manifold and the carb when you put it on. those crabs are easy to work on just remember what came from where there arent that many parts really
yeah I got a gasket on it
Someone give me measurements on them as can probably get them or have them already in the aftermarket tractor parts they have reproduced a few oil cups might be same size.
