Im sure there is, but i dont have any specs at home. look at the base materials MTR what were the tension test results? sometimes they put the max and mins in the tale @ the top. did it fail outside the HAZ? I would look at the Specs for the base metal. Id say ASTM513 as a spec. google the material to get an idea if its in the range. MDK
I have the 2005 Edition of A 513 open in front of me. As noted, the strength depends on the Grade Designation. Strength also depends on how the tubing is made - as welded, normalized, drawn, etc.
