"No offense and I am probably gonna step on a Toe here, But, The welders I need can fit for themselves." Well a rig/field WELDER ought to be able to layout,cut,fit etc.....I did not know there was any other kind
If you know a Doc that will give me a 5 gal bucket full of cortizone and a bag of needles, I am all up for it. Got a good 300amp machine in the shop just itchin for a workout and you sound like your coming to my backyard. Unfortunately my glass knee and the rest of my body are telling me "yea right"!! I am sure I could not keep up anymore. I don't know any locals (I can recommend) that are not hooked up ...but I will check around for you.
I have just what You need. It is an infusion pump that runs on batteries and hangs on a strap or belt. There is a hose that fit in it and hooks to a needle on the other end.
I use it for chemo, but it would probably pump cortizone too. You program the dosage, and it gives a squirt every so many minutes.
All You need is a Dr. wiling to move into uncharted water...
hey man u not working in little rock anymore??? we talked a little bit its been a while back though, ur from around the beebe area right, im down here around the carlisle area hate to hear bout ur knees man my dad had to have both of his replaced, u ever think bout doing any thiong with ur welder, what kind????
Hey Brian
Yea Falcon and Hawker took some serious hits when the economy turned...I was one of about 700 that got the boot, there were only 4 welders to begin with. Your not far just a skip up 31 and down 40, I am smack dab in the middle of Beebe. I have had a severe problem with arthritis since about 32 yrs old. Not a biggie I just have to be more careful of the jobs I do, no more walking iron, ladders things like that. It does not stop me from welding, just where I do it. I got a new scrip that does not "drug me up" and helps with the pain quite a bit...still trying to learn how not to overdo it since I started it. My welders I use, I got a 3020G and an older Hobart Tig/Stick machine. Somebody needs a gate/fencing typical farm/equipment repair stuff I do it for a little side cash. Right now I am put in with Pratt&Whitney and few other MRO engine places..so I might be pulling up stakes with the right offer.
Have you got steady work right now?
hey tommy
i got the same machine here not doing alot on the side work i have a sycrowave tig welder tooo i do a some work for these minnow farmers and rice farmers around here on there aluminum pipe, my main job is in little rock and a rock quarry and we so far are still working 40 hours a week, orders are down and production is not working full weeks, and talks of a lay off in maintanance are heard through the plant hopefully it won't affect me but u never know, take care man
Brian
I worked with a genuine CBI tank engineer that got into consulting.
He was sent to a project where they were fitting 3/8 floor plate. They were not getting a flat profile on the breakdowns and the contractor was wanting an idea how to make the breakdowns. He wanted to know about hydraulic rams, leaver bars, anything to make the job easier. The guy walks on the job and tells the contractor. You got two choices, either get a bigger hammer or swing the mother flocker you have harder.
I like in heavy plate fitting, being subtle gets you no where. Fitting 101 You either get a bigger hammer or swing the one you have harder. And you have only one person to blame for a bad fit up.
