Hello Guys,
I'm in need of technical answers to my queries below:
1) How many welding pass will be needed to weld a Complete Joint Penetration Butt Weld for a web plate thickness of 40,50,60, 80 and 100mm ( material grade ASTM A572 ) to a higher thick flange? Root pass to be made by FCAW and to be followed by SAW process.
a) edge preparation will be double bevel with a groove angle of 60 degrees.
b) what will be the suitable SAW electrode size to increase welding deposition.
c) ranges of required inter-pass temperature
d) what will be the required weld size ( leg ) for each particular thicknesses.
Anticipating your technical help.
Thanks...
