I have fixed them before, PIA but clean the hell out of it, and try alum wire, i found 4043 to work best, might have to run couple beads grind out then run couple more till it cleans up re-grind and clean up and make a nice pretty weld, or i have patched them too easier i think not as much crap from the inside of the tank...good luck hope it helps
