The applicable code lists the minimum information that must be recorded on the PQR. However, the more information you record the more useful the document is.
Go to the
AWS homepage and then to
Inspection Trends and then to their
Past Issues page. There are a series of articles, starting in the Spring of 2010 addressing WPSs, PQRs, and performance testing. You might find them worth your time to read. Included in the articles are sample forms that are filled out as an aid to where to place the data. There are four articles starting with the 2010 Spring edition through the Winter edition of 2011. You can start here:
http://www.aws.org/itrends/archive/2010/ For the most part, the articles attempt to keep things generic. Different codes have different requirements, but the articles should help you better understand the process.
Good luck - Al
