Right, I'm aware of WABO, not aware of Wisconsin specs, and didn't mention it, probably missed several other states as well. Sorry 'bout that. I have welded in Wisconsin, but under federal pipeline safety dot specs/API/gas company requirements. Beautiful country and very nice people. They love their brats, eh?
Still agreeing with Jwright650, where, oh where do we get these "federal certs"? I wantem bad.
Pass several super secret background tests, done that, submit to homeland security for a rectal exam, weld the elusive and special "federal structural steel" to some unknown top secrete spec? Pass some weird psychological exam? Probably caint do that anymore. But I'm a felony free white male....if I had a muslim surname and had bombed a couple National Guard Armouries in the 70's resulting in one or two deaths, I'd be a cinch under the current admin. Heck, they'd almost make me the Sect. of Defense!
Maybe I'll change my name to Jokin Tiomas Muhammed. Or Muhammed Ali. That'd get me all federal certified : ( and then I could weld ANYTHING)!
No, I guess not. Just keep trying to trudge along as an American Contractor (endangered species).
I'll have to watch out for those bridges that cross the mystical/mythical state border : ).
John
You know what is wrong with WABO that I have ran across Allan? The WABO card lists all processes. When you sign the card for one process, it does not give a place to list which process was used. So If a guy was qualified with more than one process, which I see often, and only uses one process in the last 6 months and you sign his papers, he gets his qualification extended for all processes.
Carl
Allan,
The WABO you speak about above, do they have their own document that addresses materials, qualification ranges, acceptance criteria, and other information?
Is the WABO for every industry or do they only have one specific industry sector they govern?
Thanks
Gerald
Hello Gerald, yes they do. But they take the majority of their form and fashion directly from AWS D1.1 and then add a few things, change a few things, and otherwise include various additional components. Some of the testing criteria is a little tighter for WABO than the AWS ones. If you go to www.wabo.org you can navigate through some of this information and kind of get a picture of how it all works. They are structurally oriented and not generally associated with piping, boilers, vessels, or other items of the like. Their pipe certs are aimed at cans and piles for structural purposes, no pressure or material transmission. The structural is seismic as well as general. Hope that helps a bit. Best regards, Allan
Thanks. I'll take a look at it. Interesting that they have their own. I didn't realize it was a standalone organization.
I did look through the site some. Are there any state employee's involved with the testing process ?
Yes Gerald, all of the community colleges that offer testing are using their welding labs and instructors to administer the testing. There are also private companies that offer testing as well. The WABO organization oversees and dictates how this is to be done and are responsible for the issuance of cards and the qualification/auditing of the agencies/companies/facilities doing the testing. Best regards, Allan
Thanks. Similar to the ATF program ?
What I am wondering is this. Does the state assume the full responsibility for the qualification and supporting documentation for the "State" certified welders?
Reading through the standard briefly it appears it's just another entity created to document a process (welder performance testing) that we as welding professionals should know how to do.
I noticed no Reference to D1.5. Any ideas why it was excluded other than the allowance for grinding etc ?
Thanks for your responses. The standard looks like something I would love to sit down and read fully.
Have a great day.
Gerald
WABO is a WA state non-profit corporation.
WABO testing can only by done by an approved WABO Welder Examiner.
An approved WABO Welder Examiner can only conduct testing at a WABO approved test site.
Examiners do not have to be state employees to be approved.
Test sites do not have to be run by the state to be approved.
Edit to add: WABO 27-13.3.2 lists those eligible to become approved WABO Welder Qualifying Agencies.
So it looks more like the facility is "certified" by the state and not the welder.
I don't see that the state is in the loop, as the WABO organization is a non-profit corporation.
WABO actually produces and issues the certification cards to the welder. The Approved Welder Examiner, at an approved test site, tests the welder and forwards the appropriate WABO test record forms to WABO. WABO handles all card issuance, renewals, continuity records, long term historical records, disciplinary actions for fraud, and so forth.
Hello again Gerald, likely a case of semantics when you try to follow the train of command and how to explain it. As a WABO examiner and the one responsible for our particular testing site, myself or my partner, who is also an examiner, are one of the two responsible for performing welder testing and then supplying the necessary documentation to the WABO office for them to provide a card to the welder who has completed the testing. From that point on the WABO office and the welder are the ones who deal with re-upping the certification.
We are also responsible for seeing to it that our site meets the criteria to be considered an approved testing site. We have to meet particular requirements and keep records and other things in order to continue in our testing capacity. I am scheduled for an audit as of tomorrow and will be busy making sure that everything is in order. Best regards, Allan
Good luck on the inspection tomorrow Allan.
I think one of the better things WABO does is require the test site to hold all test specimens and coupon remnants for 6 months. There is inherent accountability and fairness in this. IMO it makes it much less likely that an Examiner would fail someone who should have passed or passed someone who should have failed.
I have seen examiners (not WABO) pass stuff that was "good enough" that didn't actually pass the written criteria, and then simply throw out the pieces.... no accountability.
I thought WABO was a cheap tequila. I see the kids ordering it all the time. Cabo Wabo. I prefer Patron or Don Julio myself.
Thanks Blaster, that is a very important point that I apparently overlook quite often. They are a non-profit that is Chartered by the state so I often make that association. Best regards, Allan
