Hi Everyone,
I registered myself here as I have stumbled some problem at work with relation to welding.
I'm from Malaysia, I have worked in mass production line for electronic goods for about 8 years.
3 years ago I decided to switch into project management and only started to have some exposure to metal works.
Welding is very new to me and I until now I am still learning the trade.
I'm not sure this is the place I should be posting my problem, hoping I'll get some advise on this.
I have just completed a project of installation where welding is involved. It was on a seaport container cranes.
I am well aware that once an articled is being welded, the opposite face of the surface will have some burn marks on the paint, which needs to be repaired by standard paint repair process.
However, the opposite face is located in a confined space and requires a specific entry procedure.
I'm at the cross road now; the job awarded to me only tells me to repair affected damaged paint due to weld heat, but did not specify the job involves entry into confined space.
![eek :eek:](/f2/epx.png)
Is there any standards pertaining entering of confined space should be spelled out specifically? Can anyone point me to some reference? I have been googling up and down and couldn't find any answer.
![cry :cry:](/f2/epx.png)
Thank you. With regards, Ian T.
