Dear Sirs
ASME IX or ASME B31.3 or Both Codes shall be complied with ?
My Contractor insits on-
Primary Code is ASME IX only.
My understanding
Design/Construction Codes requirements shall always take precedence over ASME IX requirements.
For example
ASME B31.3 Mandatory requirements shall take precedence over ASME IX mandatory requirements
QG-100 SCOPE
(b) Whenever the referencing Code, standard, or specification imposes requirements different than those given
in this Section, the requirements of the referencing Code,standard, or specification shall take precedence over the
requirements of this Section.
As for WQT for High Pressure Piping ASME B31.3-Chapter IX shall be complied with.ie Mechanical Tests mandatory
Pls guide for better undestanding
By chandru6alex
Date 09-08-2016 06:20
Edited 09-08-2016 07:47
Dear Sir/Madam,
I have a doubt in interpretation of welder qualification period.
In my case, a welder is qualified by conducting qualification test during Jan,2015 as per ASME Sec-9. Tests are OK.
So, his period of qualification is Jan,2016 to June,2016. During this period, he performed a welding on job (Production weld) on March,2015. After that he didn't performed any weld regarding that initial qualification.
Now(June 2015), a welding engineer notices that his qualification going to expire. And the Engineer plans to extent his qualification by production weld, he finds out the welder performed the welding on March, 2015.
My question is,
1. The welder qualification renewal is from March,2015 to August,2015
[OR]
2.The welder qualification renewal is from June,2015 to Dec,2015.
