I'm a college student and the only thing I know is that the load is static and that the tensile stress is around 90% of the compression stress. The question is which will cause a failure first. I suppose that it doesn't matter with static load, but from experience, if you weld a vertical pillar to the ground and apply enough force on it horizontally, which side will give out first and is there a difference at all?
