Up Topic Welding Industry / General Welding Discussion / AISC Certification Standard for Steel Building Structures 06
- - By QCCWI (***) Date 03-16-2007 16:06
The new AISC standard adds some books to the "Fabricator should also have the following references readily availible" list, one of them is the  AWS Welding Quality Assurance Guideline for Fabricators (WQAG). I searched the AWS bookstore and got nothing. Can someone tell me where I can find the guideline?
Parent - - By js55 (*****) Date 03-16-2007 17:32
That seems to be what AISC does best. Add crap to the list of requirements. What a monster they're creating. Hope the coming revisions to the evaluation process improves the situation.
Parent - By eekpod (****) Date 04-28-2008 16:50
I'm trying to find this document as well and can't find it.  Has anyone heard of this WQAG?
Also since it's in the list of references that "should" be maintained, doesn't that mean it's not required just suggested?
Chris
Parent - - By jrw159 (*****) Date 04-28-2008 17:27
Gentlemen,
  Here are a couple of links. Hope they help.
Also, Chris has a point that could be valid. While not all entities utilize the words "should" and "shall" like AWS does, as a general rule "should" is a recomendation while "shall" is a requirement.  FWIW
https://www.awspubs.com/product_info.php?&products_id=475
http://store.ihs.com/specsstore/controller?event=LINK_DOCDETAILS&mid=W097&getCurVer=false&docId=FKANNAAAAAAAAAAA&mid=W097
John
Parent - - By hogan (****) Date 04-28-2008 17:44 Edited 04-28-2008 18:57
it looks like it is superseded by this
http://files.aws.org/certification/docs/b5.17-04.pdf
edited the link by JW, it should work now John...
Parent - - By jrw159 (*****) Date 04-28-2008 18:24
hogan,
  I can not get that to open up anything. But as I have stated before, I am not the most computer literate fellow on this forum.
Is it just me?
John
Parent - - By jwright650 (*****) Date 04-28-2008 18:58
John,
I edited the link, but you will still need to have Adobe reader on your computer to view the file because it is a pdf. file.
Parent - By jrw159 (*****) Date 04-28-2008 19:09
John,
  Thank you.
jrw159
Parent - By hogan (****) Date 04-28-2008 19:37
thanks
Parent - - By jrw159 (*****) Date 04-28-2008 19:42
John,
  "The file is damaged and could not be repaired" Is the message I recieved after I downloaded adobe reader.
Maybe it is just me. LOL
jrw159
Parent - - By Jeffrey Grady (***) Date 04-28-2008 20:53
jrw159,
  I opened the file very easily. It's not damaged. I suggest going to "up-dates" for Adobe Acrobat Reader and getting Adobe Acrobat 8.0 that should open any pdf file. Hope that helps you out John.
Respectfully, Jeffrey S. Grady
Parent - By jrw159 (*****) Date 04-28-2008 20:59 Edited 04-28-2008 21:02
Jeff,
  Thank you, I will try that.
John
