![](/mwf/attachments//avatars/19261-6136.jpg)
If its a Cable remote and you have a fax, I actually have drawn out a schematic and can fax it to you. Do you have an auto idler on your machine (upgrade from the original vac idler)? If so which upgrade?
Are you installing the pigtail with a toggle (recommended)? If so did it come with the remote or are you making that up yourself?
55amp DC toggle recommended for remote.
Answers these ?? and I will be able to help.
