Gerald;
here ya go!
http://asmcommunity.asminternational.org/portal/site/asm/LifelongLearning/Credit/ExtensionDiplomas/Since I'm working overseas and away from my wife, I thought this would be a brilliant way to productively use up some of those hours spent alone in the hotel room! I'll contact them as soon as I go back home in mid-January.
Achieve recognition of your achievements in learning in seven focused technical areas
The ASM Materials Engineering Institute awards extension diplomas in five focused areas of study, ranging from corrosion and general metallurgy to testing and welding metallurgy.
To achieve an extension diploma, an applicant must successfully complete either Elements of Metallurgy OR Metallurgy for the Non-Metallurgist, and a series of courses in one of the following technical specialties. To get more information on Extension Diplomas, call Jim Flynn at 440/338-5151, ext. 5221.
Applied General Metallurgy Extension Diploma
Elements of Metallurgy or Metallurgy for the Non-Metallurgist®
Plus any four (4) other course
Corrosion-Chemical & Elevated Temperature Extension Diploma
Required: Elements of Metallurgy or Metallurgy for the Non-Metallurgist®
Corrosion
Stainless Steels
Introduction to Heat Treating
Electives (select one of the following): Aluminum & Its Alloys
Principals of Failure Analysis
Ferrous Metallurgy Extension Diploma
Stainless Steels
Electives (select any two courses except): Aluminum & Its Alloys
Titanium & Its Alloys
Heat Treating Extension Diploma
Required: Elements of Metallurgy OR Metallurgy for the Non-Metallurgist®
Advanced Heat Treating
Practical Heat Treating
Practical Induction Heat Treating
Non-Ferrous Metallurgy Extension Diploma
Required: Elements of Metallurgy or Metallurgy for the Non-Metallurgist® Titanium & Its Alloys
Electives (select any two courses except): Introduction to Heat Treating
Testing & Inspection Extension Diploma
Mechanical Testing of Metals
Principles of Failure Analysis
Electives (select two of the following): Fundamentals of Non-Destructive Testing
Metallographic Interpretation
Practical Interpretation of Microstructures
Metallographic Techniques
Welding Metallurgy Extension Diploma
Welding Inspection & Quality Control
Any three other courses
Jon
