Up Topic Welding Industry / Technical Discussions / SMAW combined w/ FCAW
- - By chesauxchris Date 04-21-2014 18:19
Can SMAW and FCAW be combined in the same weldment, and if so which electrodes?
Parent - - By jbndt (**) Date 04-23-2014 04:26
Chris,
Usually yes ... IF ... it is allowed in the contract documents.
The WPS for the joint being welded will specify which 'stick' and which 'wire' etc.
Be very careful as a non compatible combination WILL cause weld failures.
Cheers,
jb
Parent - By SCOTTN (***) Date 04-23-2014 16:30
Here's a related article "The Effects of Intermixed Weld Metal on Mechanical Properties", that discusses SMAW and self shielded FCAW:
http://www.aws.org/wj/supplement/Quintana/ARTICLE3.pdf
Parent - By Len Andersen (***) Date 04-26-2014 19:15 Edited 11-20-2015 20:09
Ladies and Gentlemen,
     Yes but  ---- ! If you want to get paid doing it I would require a WPQR and WPS's. I have reviewed a few of such.  Been an engineer and into welding for plus 20 years / five patents. Hope this is helpful.
    Sincerely
        Len Andersen     len@lenandersen.com
          914-536-7101
        www.lenandersen.com
PS - I am looking for a job !
Parent - - By Joey (***) Date 04-29-2014 00:36
These combinations are common, but you must have supporting WPS & PQR
SMAW - root pass + FCAW - capping
GTAW - root pass + SMAW - capping
GMAW - root pass + SAW - capping
Parent - - By nantong (**) Date 04-29-2014 05:49
Does this only apply to pre-qualified procedures ?
Parent - By Joey (***) Date 04-29-2014 16:44
No
