Up Topic American Welding Society Services / Certifications / D1.1 WPS Positions Qualified
- - By Testem Date 04-23-2014 17:40
The question has been brought up and I’ve heard a couple of different interpretations in the past about what positions are qualified with and without charpy impacts.  In AWS D1.1, Table 4.2 note a, says that one test plate, pipe, or tube shall be required for each qualified position.  I understand that but when charpy impacts are required, table 4.6, variable 6 states that the 3G vertical up test qualifies for all positions and vertical down.  The question is, do we need to run all three positions and just perform charpy impacts on the vertical or can we get all positions qualified by welding just one plate in the 3G uphill progression?  How do you interpret this?
Parent - By SCOTTN (***) Date 04-23-2014 18:32
As stated in the commentary of the 2010 D1.1, at C-4.8, "In Table 4.6, the Essential Variable on line 6 eliminates the need for CVN testing in all positions but does not change the requirements of Table 4.5 regarding welding positions".
