1 213 14 15 16 1790 91 Previous Next
Topic User Posts Last Post
- D1.1 2015 Clause 5.3.2.5 (2) question - what/where is (c) 357max 4 05-20-2016 02:25
- BOLTED SLIP CRITICAL CONNECTIONS ( STACKING WASHERS ) billk63 3 05-19-2016 19:17
- Welder Qualifications The Ruffian 8 05-19-2016 02:42
- AWS D1.1 : 2015 - Table 4.2, note d 4345402 1 05-17-2016 15:05
- Time Between Passes Joey 7 05-17-2016 03:59
- 2 different filler metals acceptable? BLAZER 8 05-16-2016 17:21
- GE USM Go+ Lawrence 4 05-08-2016 17:24
- Busy day ! Lawrence 4 05-06-2016 12:07
- Tack Weld Break Test Dreizehn 4 05-05-2016 19:23
- Stud Welding - AWS D1.1 jbfab 1 05-05-2016 17:04
- API Standards for Europe phinojosar 2 05-03-2016 04:51
- NDT on grinded welds - Reason kar80 2 05-03-2016 02:02
- API 5L X70 jerrymcfly 4 04-29-2016 17:59
- TYK Connection Qualification Junius 4 04-26-2016 14:16
- Nondestructive testing David David 5 04-25-2016 16:45
- tack weld for orbital weld Ronen lev 2 04-22-2016 12:21
- D1.2 6G bend test KBNY 17 04-21-2016 17:53
- Can you have too much penetration? PHOTO TIME!! MRWeldSoCal 14 04-11-2016 22:08
- procedure qualifications ali zahoor 3 04-11-2016 04:26
- ASNT level 3 for self owned company PFI 3 04-03-2016 16:35
- CWI API 1104 certification galencwi 8 03-31-2016 15:44
- Porosity vs. End Crater k-maes 24 03-24-2016 13:31
- Frequency range in essential variables MRWeldSoCal 9 03-23-2016 18:50
- Qualifying Unusual Brazed Joint benninghoffsam 1 03-23-2016 00:03
- Distance between 2 longitudinal welds of different panels joao56777 6 03-21-2016 01:52
