Up Board Welding Industry / Metallurgy
1 2 314 15 Previous Next
Forum topics on metallurgy and metallurgists
Topic User Posts Last Post
- Stainless Steel Pipe Grades libowei111 1 03-29-2025 05:25
- Steel manufacturer spec differs from ASME spec qcrobert 1 10-31-2023 16:16
- PWHT Deepu VB 2 06-02-2021 10:54
- Filler Metal help needed Pawndave 5 03-27-2021 16:07
- FCC, BCC, HCP???? toddler 2 01-30-2021 18:56
- Possibilities of transvers weld crack Dhrumil Chauhan 2 09-03-2020 12:44
- Phase Diagrams Atuuel 2 04-02-2020 00:08
- Welding on Hardened 8620 Tool Steel, any suggestions? Tigger1106 7 12-27-2019 23:28
- CTOD Testing stef33000 1 11-09-2019 15:47
- PWHT Question jypsee009 2 10-09-2019 23:26
- metallurgy, HAZ, distortion kcd616 27 08-08-2019 12:23
- Requirement of delayed NDT on API 5L X65 LINE PIPE Welding syjuscaria 2 08-05-2019 11:55
- ASTM A572 Gr60 HR Plate Surface Appearance bozaktwo1 11 06-07-2019 21:29
- Hardness of weld - GTAW ER70S-3 HeidiK 4 02-26-2019 13:49
- PWHT sreedhar 8 02-26-2019 11:19
- Levels of discoloration in ASME BPE Code - Sanitary Welding. andcord777 1 08-10-2018 12:14
- Large Forgings - Martensitic Stainless engineer1984 9 08-07-2018 11:47
- PWHT TEMPERATURE RANGE Deepu VB 6 07-19-2018 06:26
- Need infromation on torque spec for a M12-1.75 weld nut halamed 1 07-11-2018 15:26
- 6061-T4 SheetMetalGuy 1 06-15-2018 16:43
- Stainless Pipe Weld Sugar/Oxidation DannyAgudelo 10 06-06-2018 00:56
- Filler metal identification josito 15 05-11-2018 03:00
- A106 Gr.B NACE MR0175 minimum requirements Maad 3 03-28-2018 13:02
- Blueish color observed after flush grinding in SMAW 7018 . Abdul Azeem 3 02-22-2018 07:49
- Stress Relief BWolfe 17 02-13-2018 13:09
