Up Topic Welding Industry / Technical Discussions / cellulosic and rutile
- - By aliabdou93 Date 08-25-2019 18:27
can i use 6010 for the root & 6013 for the fill/cap ?
Parent - - By 803056 (*****) Date 08-26-2019 01:05
What was qualified. They are different F numbers, so a different PQR may be needed if the current WPS doesn't permit it.
Then again, if the governing code is the Farm Code, it is perfectly fine until it breaks.
Parent - - By aliabdou93 Date 08-26-2019 08:00
it's qualified yes but they aren't the same F number , so there is a problem ?
Parent - - By SWN1158 (***) Date 08-26-2019 13:57
Do the project specs limit you to E70xx ?
Parent - By aliabdou93 Date 08-27-2019 06:01
NO
Parent - - By 803056 (*****) Date 08-26-2019 15:49
Read my response.
Parent - By Shane Feder (****) Date 08-27-2019 10:44
Yes, there is a problem.
