Up Board Welding Industry / Metallurgy
1 2 3 414 15 Previous Next
Forum topics on metallurgy and metallurgists
Topic User Posts Last Post
- Tatanium, phosphoric, and chromic acid ctacker 1 12-19-2017 05:39
- weld procedure for Four wheel drive input shaft firstpass 1 11-16-2017 04:10
- Unmarked Welding Wire Identification hunterisawesome 9 10-27-2017 12:00
- Bauschinger effect influence on Creep life Eutectic 1 08-04-2017 06:58
- 7010 A1 vs. Atom Arc 7018 2006strat 5 04-05-2017 13:54
- Stainless Cracking? 2006strat 4 04-05-2017 12:58
- Ancient steel MRWeldSoCal 15 12-02-2016 07:39
- Advice on where to go from here MRWeldSoCal 8 12-02-2016 07:15
- post heat for 6061-T6 kcd616 3 08-19-2016 12:56
- share kcd616 1 08-08-2016 12:02
- AWS D1.8 FCAW-S intermixing with other processes Richard Cook 2 08-02-2016 22:06
- share kcd616 1 07-30-2016 07:43
- WPS for AISI 4145 with 140,000 psi Tensile strength IbrahimGadir 5 07-03-2016 07:57
- why alloy steels harden on cooling pradeep4u 6 04-23-2016 04:15
- Heat treatable filler rod waqasmalik 8 03-13-2016 13:40
- share kcd616 4 02-16-2016 07:10
- weldability of Fe-Ti alloy kcd616 3 12-17-2015 03:58
- Welding Metallurgy ssbn727 5 12-01-2015 14:18
- HSLA welding using 100% co2 mdudhiya007 7 11-29-2015 12:45
- aisi/sae steel designations kcd616 1 11-08-2015 13:11
- interesting read kcd616 1 10-25-2015 13:56
- anneling vs stabilization heat treatement ionutamartei 1 10-18-2015 12:48
- reading material kcd616 2 10-17-2015 01:48
- 2 charts kcd616 2 10-17-2015 01:45
- share kcd616 1 09-01-2015 23:20
