1 212 13 14 15 1689 90 Previous Next
Topic User Posts Last Post
- Conducting NDT (UT,MT,PT) before heating arif 3 06-20-2016 16:14
- 6010 Weld Test dew84 10 06-16-2016 03:12
- Volts and Amps at Power source or at Arc billk63 14 06-14-2016 16:15
- CJP qualification applied to a fillet around a diameter 4345402 1 06-10-2016 18:13
- Position During Qualification Test NathanB52 7 06-10-2016 14:01
- How to write a WPS (ISO 15614-1) weldnote 5 06-10-2016 12:29
- Hardness in PQR/Two PQR supporting a single WPS Sambuddha 3 06-10-2016 08:23
- WPS WITH IMPACT TEST AS PER ASME SECTION IX mujibali_m_a 9 06-07-2016 08:05
- MT guy not doing his job correctly MRWeldSoCal 42 06-03-2016 20:58
- Welders qualified thickness ranges Richman 5 05-28-2016 00:32
- Benefits of Specifying Phased Array Ultrasonic Testing for ! Len Andersen 1 05-20-2016 18:04
- D1.1 2015 Clause 5.3.2.5 (2) question - what/where is (c) 357max 4 05-20-2016 02:25
- BOLTED SLIP CRITICAL CONNECTIONS ( STACKING WASHERS ) billk63 3 05-19-2016 19:17
- Welder Qualifications The Ruffian 8 05-19-2016 02:42
- AWS D1.1 : 2015 - Table 4.2, note d 4345402 1 05-17-2016 15:05
- Time Between Passes Joey 7 05-17-2016 03:59
- 2 different filler metals acceptable? BLAZER 8 05-16-2016 17:21
- GE USM Go+ Lawrence 4 05-08-2016 17:24
- Busy day ! Lawrence 4 05-06-2016 12:07
- Tack Weld Break Test Dreizehn 4 05-05-2016 19:23
- Stud Welding - AWS D1.1 jbfab 1 05-05-2016 17:04
- API Standards for Europe phinojosar 2 05-03-2016 04:51
- NDT on grinded welds - Reason kar80 2 05-03-2016 02:02
- API 5L X70 jerrymcfly 4 04-29-2016 17:59
- TYK Connection Qualification Junius 4 04-26-2016 14:16
