Not logged in
American Welding Society Forum
Forum
AWS Website
Help
Search
Login
Board
Welding Industry
/ Technical Discussions
1
2
3
4
236
237
Info
Topic
User
Posts
Last Post
Weld build-up/repair of structural steel flange
Jovi Zhu
7
09-23-2021 16:41
AWS D1.5:2020 7.8.2 clarification of plates position
Quality0537
2
06-10-2021 20:52
D1.5 and weld bead method of identification restrictions
Quality0537
3
05-28-2021 22:09
impact temperature reductions per Table UG84.2
aravindkm002
2
05-28-2021 01:07
Distance between two welds
Vansledge
7
05-10-2021 11:42
Welder/welding operator Requalification (API 1104)
Vansledge
5
04-05-2021 19:12
Creep Testing
Atuuel
3
03-18-2021 06:28
How to determine the TKY connection as per AWS D1.1
quocbui
22
03-12-2021 20:19
17-4PH H1075 - PWHT condition
Rakhul
1
02-17-2021 11:55
Pqr Qualified with Ed.2015 in valid now under Ed.2020???
Marcello
4
10-22-2020 06:42
F7A2 wire on HPS 70W to HPS 70W
Tommyjoking
6
07-17-2020 07:08
WPS Requirements- joint designation
cbutts
3
07-15-2020 11:21
Maxiumum heat input exceeded
Pssssst
12
07-06-2020 13:52
undersized fillet welds
Roguebear
3
06-17-2020 02:58
Hydrogen bake out and PWHT requirement
4
06-15-2020 12:58
Fe % in Inconel 625 overlays
Atuuel
2
06-06-2020 13:04
plugging holes in a column
ididntdoit89
7
05-09-2020 13:50
300 Series Stainless Steel using RMD/STT
mwilliams93
5
04-22-2020 10:19
Suitable Material for Argon Gas Lines
jd369
10
04-09-2020 12:56
Tensile strength Issue on WPS
Vansledge
10
03-31-2020 17:55
FCAW E71A Dual Shield Questions?
louis2
10
03-18-2020 12:19
Lamellar structure
waqasmalik
4
03-09-2020 18:42
Addition of Ti in HSLA steel
Mark Anthony Nofuente
5
03-06-2020 06:16
Welder/Welding operator Position and thickness qualified
Eutectic
5
02-11-2020 14:10
CS Corrosion
Amr Elsayed
4
02-02-2020 14:47
Forum
AWS.org
- Forum News & Help
American Welding Society Services
- Certifications
- Conferences & Shows
- Technical Standards & Publications
- AWS Learning & Education
Welding Industry
- General Welding Discussion
- Technical Discussions
- Inspection & Qualification
- Processes
- Welding Fundamentals
- ASME Codes
- Welding Safety
- Metallurgy
- Welding Documents & Downloads
Welders and Inspectors
- Education & Training
- Welding Equipment Classifieds
Sections
- Section 7: San Francisco
- Section 32: Rochester
- Section 39: Colorado
- Section 41: Puget Sound Olympic
- Section 55: Arizona
- Section 81: Nebraska
- Section 110: North Florida
- Section 112: Florida West Coast
- Section 135: Nevada
- Section 156: Inland Empire
Chit-Chat & Non-Welding Discussion
- Off-Topic Bar and Grill
Powered by
mwForum
2.29.2 © 1999-2013 Markus Wichitill
