1 2 3 4236 237 Previous Next
Topic User Posts Last Post
- AWS D1.5:2020 7.8.2 clarification of plates position Quality0537 2 06-10-2021 20:52
- D1.5 and weld bead method of identification restrictions Quality0537 3 05-28-2021 22:09
- impact temperature reductions per Table UG84.2 aravindkm002 2 05-28-2021 01:07
- Distance between two welds Vansledge 7 05-10-2021 11:42
- Welder/welding operator Requalification (API 1104) Vansledge 5 04-05-2021 19:12
- Creep Testing Atuuel 3 03-18-2021 06:28
- How to determine the TKY connection as per AWS D1.1 quocbui 22 03-12-2021 20:19
- 17-4PH H1075 - PWHT condition Rakhul 1 02-17-2021 11:55
- Pqr Qualified with Ed.2015 in valid now under Ed.2020??? Marcello 4 10-22-2020 06:42
- F7A2 wire on HPS 70W to HPS 70W Tommyjoking 6 07-17-2020 07:08
- WPS Requirements- joint designation cbutts 3 07-15-2020 11:21
- Maxiumum heat input exceeded Pssssst 12 07-06-2020 13:52
- undersized fillet welds Roguebear 3 06-17-2020 02:58
- Hydrogen bake out and PWHT requirement - 4 06-15-2020 12:58
- Fe % in Inconel 625 overlays Atuuel 2 06-06-2020 13:04
- plugging holes in a column ididntdoit89 7 05-09-2020 13:50
- 300 Series Stainless Steel using RMD/STT mwilliams93 5 04-22-2020 10:19
- Suitable Material for Argon Gas Lines jd369 10 04-09-2020 12:56
- Tensile strength Issue on WPS Vansledge 10 03-31-2020 17:55
- FCAW E71A Dual Shield Questions? louis2 10 03-18-2020 12:19
- Lamellar structure waqasmalik 4 03-09-2020 18:42
- Addition of Ti in HSLA steel Mark Anthony Nofuente 5 03-06-2020 06:16
- Welder/Welding operator Position and thickness qualified Eutectic 5 02-11-2020 14:10
- CS Corrosion Amr Elsayed 4 02-02-2020 14:47
- Shear Connector WPS (Welding Through Metaldeck) ing.jorgep 10 01-27-2020 15:16
