Up Board Welding Industry / Welding Fundamentals
1 2 319 20 Previous Next
Share your insights
Topic User Posts Last Post
- L Sticky - Structural Steel Shape Charts jwright650 1 11-12-2010 18:13
- using filler wire ER 80 SB2 inwelding P22 PIPE pradeep4u 1 04-27-2024 12:22
- WPS/PQR/WPQ soldering HAFHARVARD 3 09-13-2023 20:09
- Intermittent Staggered welds (clarity on starts) PFI 3 06-13-2023 02:56
- welding of dissimilar metals pradeep4u 1 12-27-2022 05:18
- Butt welding 60mm thick Aluminium EN AW 6082 T6 Plates Navdeep 2 02-13-2021 22:06
- Electrode E6022 (E 4322) Kishore 1 12-31-2019 01:14
- heat input MILLSCALE 3 11-18-2019 07:18
- All around fillet welding SAYoung 13 07-24-2019 10:39
- Porosity and Slag in SAW supermoto 3 07-10-2019 09:40
- Welding of clad materials Baraneedharan 6 05-23-2019 14:31
- Expectations of Welders Maggs47 18 05-15-2019 12:33
- Mectric system , converting , blueprints ???? leighann hanson 13 05-06-2019 19:52
- Gr 91 post heating? justin81 1 10-29-2018 07:53
- Tension vs. Shear Maggs47 9 09-05-2018 11:53
- pressure drop calculation of pipe through hole apoorvamehta 1 08-18-2018 07:52
- D1.1 Pre Qualified Joint - B-L1b Rdavid3 3 06-23-2018 00:40
- does WeldProc Welding Software prepare welding procedure sp weldproc133 1 05-15-2018 10:46
- fixing office chairs Fritz T Katt 11 04-11-2018 07:34
- Gettin' TIGgy wid it... kung fu panda 4 03-28-2018 00:16
- 4130 to C-1117 Welding Consumable snehal2754 2 03-11-2018 19:44
- HI LO on welding of pipelines MILLSCALE 4 02-12-2018 20:01
- Temperature Tie Ins On Onshore pipelines MILLSCALE 1 02-10-2018 10:47
- Weld Acces holes - AWS FIGURE 5.2 Andyman 5 01-08-2018 10:18
- hot pass in welding pradeep4u 5 12-24-2017 12:22
