1 2 3 4 590 91 Previous Next
Topic User Posts Last Post
- Range Qualified in WPS AWS D1.1 (Filler Metal) LeoSan 1 04-09-2020 12:45
- Thickness for Welder Qualification according to QW 404.30 thinhnguyen 5 03-23-2020 07:23
- WELD REPAIR (ASME SEC IX) ganeshrnair9 2 03-15-2020 17:23
- Material Thickness on Weld Test snutt 4 02-02-2020 16:12
- D1.5 PQR/WPS testing fsirk 4 01-30-2020 14:27
- AISC 360 vs 341 K area & Post Weld Visual Inspection Lawrence 16 01-29-2020 15:31
- D1.6 Prequalification dabel 10 01-27-2020 22:01
- NDT Experience Hours brownl21 7 01-20-2020 21:39
- AWS D1.6 Fillet Qualification CC4846 7 01-16-2020 20:14
- D1.5 endorsement exam study materials fsirk 19 01-15-2020 14:33
- Deck installation 24/8 puddle weld pattern jwright650 10 01-06-2020 14:30
- Suggestion on inspection tools tonixwelds 13 01-01-2020 17:57
- Individual Fillet Weld Gauges? bozaktwo1 3 12-20-2019 16:05
- 6G Up or 6G Down Josh Waymack 4 12-19-2019 20:41
- doing research on PQR/WPS kennymox510 12 12-13-2019 17:29
- undrecut criteria interperetation cbutts 4 12-12-2019 16:43
- TKY Back-up Weld stef33000 9 12-11-2019 03:30
- Would these 1" side bend specimens pass or fail. zanic07 3 12-05-2019 13:31
- HSS bracing (lateral frames) jwright650 21 11-20-2019 15:22
- Switching to 2G snutt 3 11-15-2019 12:31
- Serving as Weld Inspector for Structural Steel and Aluminum CAM 3 11-12-2019 12:03
- Configuration of Different Base Metal Thickness stef33000 1 11-09-2019 16:14
- Macro TKY Joint Root Profile stef33000 1 11-09-2019 15:25
- Tack Welders retest to Weld snutt 5 10-30-2019 13:31
- NDT Methods Kade123 5 10-27-2019 15:22
