Not logged in
American Welding Society Forum
Forum
AWS Website
Help
Search
Login
Board
Welding Industry
/ Technical Discussions
1
2
37
38
39
40
41
236
237
Info
Topic
User
Posts
Last Post
Prequalified joint for Carbon Steel Pipe welding
Mark Anthony Nofuente
1
10-16-2012 03:59
Underwater Welding and Cutting Now !
Len Andersen
1
10-15-2012 13:30
GMAW Spray - Effects of Wire Size
Tyrone
30
10-15-2012 10:58
What is the correct symbol for a joint that has two diff gro
rmdrmd15
9
10-10-2012 16:34
weld pipe to the thicker seamless pipe
johnjava
16
10-10-2012 00:41
Procedure Qualification Plate to Pipe
LilWilly
1
10-09-2012 20:34
Carbon Pick Up from Air Arc?
Blaster
16
10-09-2012 00:16
weld leg size
johnjava
37
10-02-2012 17:28
SS400 against A36
5
10-01-2012 11:16
Heard of what ever that can weld pipe from the inside?
Len Andersen
6
09-30-2012 22:17
2 welders on the same piece of steel
elmo
26
09-24-2012 03:58
WPQR
4
09-24-2012 02:19
Base metal build up
midwelder
8
09-19-2012 11:01
Moisture in metal or chemical reaction?
S. WINAI
22
09-16-2012 17:57
Combination welding process
muka_sankar
10
09-14-2012 08:28
Need help with impact test on carbon steel
JBOLDUC
6
09-11-2012 10:55
SAW Welding thin plate.
S. WINAI
8
09-06-2012 05:16
WPQR for Plate & Pipe
3
09-04-2012 08:42
E6010/FLUXCORE
carlkukol
3
08-31-2012 21:15
Flashback propagation through the hose
devo
10
08-31-2012 10:30
Company Weld Program >> Need some help<<
PFI
4
08-28-2012 17:18
requalification of welders Electrode change???
MKNIK
6
08-27-2012 10:15
all around or not for intermittent weld on circular flange?
dsb1829
9
08-23-2012 18:13
Flame cutting equipment used for preheating a weld
MKNIK
18
08-22-2012 16:53
OES Test
Joey
12
08-22-2012 09:35
Forum
AWS.org
- Forum News & Help
American Welding Society Services
- Certifications
- Conferences & Shows
- Technical Standards & Publications
- AWS Learning & Education
Welding Industry
- General Welding Discussion
- Technical Discussions
- Inspection & Qualification
- Processes
- Welding Fundamentals
- ASME Codes
- Welding Safety
- Metallurgy
- Welding Documents & Downloads
Welders and Inspectors
- Education & Training
- Welding Equipment Classifieds
Sections
- Section 7: San Francisco
- Section 32: Rochester
- Section 39: Colorado
- Section 41: Puget Sound Olympic
- Section 55: Arizona
- Section 81: Nebraska
- Section 110: North Florida
- Section 112: Florida West Coast
- Section 135: Nevada
- Section 156: Inland Empire
Chit-Chat & Non-Welding Discussion
- Off-Topic Bar and Grill
Powered by
mwForum
2.29.2 © 1999-2013 Markus Wichitill
