1 2 3236 237 Previous Next
Topic User Posts Last Post
- L Forum Rules, Regulations and Disclaimer - 1 08-10-2005 16:09
- use of ER 80S B2 in welding p22 material pradeep4u 3 05-05-2024 01:42
- Welding Consumables for Alloy 825 Sambuddha 2 04-02-2024 08:52
- Lamination - Welded Base Plate Distilled 5 02-29-2024 12:55
- T-Joint Gaps - Fillet Weld Distilled 15 02-23-2024 21:46
- CAT D NDE HAFHARVARD 1 10-17-2023 23:48
- weld symbol on drawing meaning pradeep4u 7 10-08-2023 12:21
- Gr 91 welding and post heating justin81 6 06-13-2023 08:55
- 75/25 Gas on Structural Steel SWN1158 6 06-13-2023 02:46
- Measuring the dew point at the welding source. Tevis 11 04-30-2023 03:42
- welding of dissimilar metals pradeep4u 9 03-17-2023 19:42
- Repair of Base metal ididntdoit89 10 02-18-2023 16:28
- 410s overlay Atuuel 2 10-11-2022 21:12
- D17.1:17 GTAW Manual PQR Qualifications - Previous editions PrettyBlueLight 2 07-20-2022 13:07
- HT Hardened 4130 base materials to weld BryantB 1 07-19-2022 18:14
- Minimum holding time for PWHT as per ASME Sec VIII Div I Pallawit Dubey 3 06-15-2022 08:48
- WPS Qualification - CJP Groove Welds, AWS D1.1 2015 vs. 2020 jxsnyder 3 04-29-2022 12:05
- Need help: check the bevel/ groove angle after backgouging binhjack 2 03-19-2022 18:45
- Neep input......Welding 304 stainless to 10B38 steel obowhunter2 3 02-16-2022 20:56
- AWS D1.1 2020 WPS Wall Thickness Qualified Firefly 3 02-03-2022 22:59
- Weld build-up/repair of structural steel flange Jovi Zhu 7 09-23-2021 16:41
- AWS D1.5:2020 7.8.2 clarification of plates position Quality0537 2 06-10-2021 20:52
- D1.5 and weld bead method of identification restrictions Quality0537 3 05-28-2021 22:09
- impact temperature reductions per Table UG84.2 aravindkm002 2 05-28-2021 01:07
- Distance between two welds Vansledge 7 05-10-2021 11:42
