Not logged in
American Welding Society Forum
Forum
AWS Website
Help
Search
Login
Board
Welding Industry
/ Technical Discussions
1
2
3
4
5
6
236
237
Info
Topic
User
Posts
Last Post
Preheat on Ibeams for stiffeners and brackets?
Natebrody11
6
09-19-2019 16:13
Impact toughness property-Basic coated Electrodes
Baraneedharan
2
09-16-2019 14:51
Welding Flux composition
Prasanta
2
09-10-2019 19:44
Flux composition
dalipmengi
13
09-10-2019 19:37
Argon / Nitrogen Shielding Gas for Aluminum
Scott Griskavic
2
08-31-2019 14:08
cellulosic and rutile
aliabdou93
7
08-27-2019 10:44
Acceptance Criteria for Single Tungsten lnclusion API1104
Abhi Thakkar
7
08-11-2019 13:36
WPQR QUALIFICATION OF FILLET WELD WITH IMPACT REQUIREMENT
GOPI DELLNER
4
08-06-2019 10:54
Is AWS D1.5 Applicable to Bridge Pipe Pile?
Clifford
4
07-27-2019 21:37
Any material on how to weld pipe of 5 inchurch and 10mm thic
Ovoss
1
07-17-2019 11:50
D1.5 PQR
dave8991
9
07-08-2019 19:12
Fillet Welds on Lifting Lugs
dylansegura2
3
07-01-2019 11:54
AWS D1.1- Welder qualification test
janidevang
3
06-26-2019 21:27
SS304 PLATES WELDED WITH 308L HAVING RUST AND MEGNETISM
GOPI DELLNER
11
06-19-2019 14:59
Surface Indentation
newb
2
06-11-2019 19:53
Frame welding
oldschool59
13
06-10-2019 11:09
D1.1 2015 > Table 3.7 > SAW angle interpretation
supermoto
1
06-03-2019 19:39
ASTM A36M steel LP turbine inner casing weld built up
bitra328
4
05-31-2019 16:29
D1.6 minimum preheat
SWN1158
3
05-31-2019 01:16
Table 4.10 in D1.1 Welder and Welding Operator Qualification
SWN1158
7
05-23-2019 20:13
Silicon deposition in weld bead
Bhargav
14
05-16-2019 17:09
D1.5 Heat input averages
jwright650
26
05-08-2019 15:14
Welding progression to reduce Stress concentration & other
Mohammed Raheel
5
05-07-2019 12:13
Distortion of SS pipe
Shmally
5
05-03-2019 20:35
Minimum distance between Welded splice joint in I beam
saruncivil
5
04-30-2019 05:16
Forum
AWS.org
- Forum News & Help
American Welding Society Services
- Certifications
- Technical Standards & Publications
- Conferences & Shows
- AWS Learning & Education
Welding Industry
- General Welding Discussion
- Technical Discussions
- Inspection & Qualification
- Welding Fundamentals
- Processes
- ASME Codes
- Welding Safety
- Metallurgy
- Welding Documents & Downloads
Welders and Inspectors
- Education & Training
- Welding Equipment Classifieds
Sections
- Section 7: San Francisco
- Section 32: Rochester
- Section 39: Colorado
- Section 41: Puget Sound Olympic
- Section 55: Arizona
- Section 81: Nebraska
- Section 110: North Florida
- Section 112: Florida West Coast
- Section 135: Nevada
- Section 156: Inland Empire
Chit-Chat & Non-Welding Discussion
- Off-Topic Bar and Grill
Powered by
mwForum
2.29.2 © 1999-2013 Markus Wichitill
