1 2 3 489 90 Previous Next
Topic User Posts Last Post
- "Certified Welders" carried over from Members Only Forum welderbrent 2 07-13-2021 18:06
- D1.3 Welder Qualification Testing at New Employment CAM 6 06-23-2021 15:41
- Demonstration Test for SWPS qcrobert 2 06-16-2021 18:02
- AWS D1.2 - Procedure Qual - Dissimilar thicknesses 4345402 2 05-28-2021 22:13
- 1104 In Service Sleeve test opinions needed. Pawndave 4 05-17-2021 12:40
- Qualifying Single Bevel Per clause 4 ShayKe 5 04-12-2021 22:41
- Buildup WPS AWS D1.1 Seymour86 6 03-28-2021 19:58
- Measuring fillet weld size; tube intersections BryantB 13 03-28-2021 14:23
- Test specimen width SWN1158 7 03-26-2021 16:22
- CWI career opportunities Wyatt Ellis 3 03-23-2021 16:57
- D1.1 2020 changes Wyatt Ellis 8 03-04-2021 14:22
- Plug / Slot weld symbol question Wyatt Ellis 2 03-02-2021 17:55
- Welder qualification by using RT as per AWS D1.1 aravindkm002 19 02-23-2021 02:40
- AWS D1.5 single pass fillet SAW Steve Parmelee 2 02-11-2021 21:18
- Porosity in aluminum PQR RT BryantB 9 10-28-2020 16:16
- Visual Jarhead1 4 07-25-2020 00:51
- welding performance of less than 3/8'' and without backing ShayKe 4 07-15-2020 14:19
- visual over radiography, and visual rejection under magnific Gigimom 14 05-15-2020 04:13
- PQR for A36 to A27 Grade 65-35 ScottF 3 05-13-2020 19:48
- Prequalified Base Metals snutt 13 04-09-2020 21:14
- Range Qualified in WPS AWS D1.1 (Filler Metal) LeoSan 1 04-09-2020 12:45
- Thickness for Welder Qualification according to QW 404.30 thinhnguyen 5 03-23-2020 07:23
- WELD REPAIR (ASME SEC IX) ganeshrnair9 2 03-15-2020 17:23
- Material Thickness on Weld Test snutt 4 02-02-2020 16:12
- D1.5 PQR/WPS testing fsirk 4 01-30-2020 14:27
