1 211 12 13 14 15236 237 Previous Next
Topic User Posts Last Post
- Pipe to plate weld AWS D1.1:2015 Michael Simone 4 05-04-2017 15:06
- A516 60 PRESSURE VESSEL STEEL umutyasinkoc 1 05-03-2017 06:47
- 38 Cr Mo AIA Sambuddha 1 04-21-2017 05:31
- Welding Symbol kashif.annu 19 04-14-2017 00:35
- Usese of prequalified WPS gm hdec 2 04-12-2017 11:13
- In D17.1 is tungsten an essential or noessential variable walkerjw 8 04-07-2017 10:46
- ISO WELD SYMBOL INTERPRETATION 100perpen 15 03-28-2017 12:54
- m kashif.annu 4 03-28-2017 11:44
- cladding WPS for pipes Reuben 4 03-21-2017 21:43
- Piping Joey 4 03-21-2017 19:49
- AWS D1.1 ambiguity in qualification of WPS and welder Mayur 2 03-20-2017 21:36
- WPS teo_ie 6 03-13-2017 08:20
- LOCATION OF IMPACT TEST ON HAZ ACCORDING TO UG-84 (Ed.2013) BorjaSpain 9 03-11-2017 01:37
- Need WPS for welding Carbon Steel to Brass - GTAW mittajith 2 03-05-2017 22:50
- Resistance seam welding problems - Help needed Raviatluri 2 03-01-2017 12:13
- AWS D1.1_2015- 6GR PQR Qualification & Mock-Up Test Nalla 2 02-23-2017 13:52
- SA335 P91 Butt joint welding rvraman0 3 02-21-2017 21:31
- weld ripples Rakesh Mishra 3 02-05-2017 15:47
- AWS D1.5/D1.5M Vs D1.1/1.1M Neelan 2 01-30-2017 11:42
- Remelting HAZ during rework of inconel 600 tubing Kix 43 01-25-2017 23:29
- MMAW Recommendation srinivasc 3 01-03-2017 17:56
- Root gap for OD 44.5mm Boiler Hanger Tube Stevem1968 2 12-30-2016 14:05
- CORRECT WELD SYMBOL scole90 5 12-21-2016 17:28
- ASME B31.8 Pipeline Field Cold Bend Requirements Toey TNDT 1 12-20-2016 16:46
- Is Hot Working allowed after hydrotest? negarmansoori 2 12-20-2016 09:56
